MM 11 with Jitsi Plugin
i installed MM 11 an dtried to upload the latest jitsi plugin release from github. I chose the file, pressed “upload” but then nothing happens - no log entry.
The file is an tar.gz file which should be ok, right?
Any suggentions?
Thx in advance, Mucki
Sorry, solved the problem by manual install within the plugins folder. works.
