CGonzalo
(Gonzalo)
July 12, 2018, 9:02am
1
Hi guys,
I try to embed Jitsi with Mattermost.
I configure my Mattermost appliance ([Mattermost Team Edition Virtual Machines ]) in local machine, but I cannot set my plugin Jitsi within Mattermost. [GitHub - mattermost/mattermost-plugin-jitsi: Jitsi plugin for Mattermost ]
But i can not make that this worth for me…
I would appreciate your help.
Thank you!
amy.blais
(Amy Blais)
July 12, 2018, 1:03pm
2
Hi @CGonzalo ! Thank you for reaching out.
The best option might be to directly contact the maintainer of the plugin, in this case Sean Sackowitz - maybe you could join our build server and you can DM him there or ask him in a public channel such as Peer-to-peer Help or Developer Toolkit . Other community members and our engineers might be able to help as well in the channels!
CGonzalo
(Gonzalo)
July 12, 2018, 1:37pm
3
Hi @amy.blais ! Thank you for your response.
It’s fine, i will contact with him for this problem.
Anyway, if i found the solution, i will post here there.
Thank you!
jadjay
(Jadjay)
April 15, 2019, 11:35am
4
@CGonzalo Hello,
We’re still waiting for your solution
jasonblais
(Jason Blais)
April 15, 2019, 11:52am
5
@jadjay @CGonzalo If you’re experiencing issues with the Jitsi plugin, you may also open a new issue in the GitHub repository so the maintainer can help review: https://github.com/seansackowitz/mattermost-plugin-jitsi/issues
PackElend
(Pack Elend)
January 12, 2020, 7:37pm
6
so what is the solution
Is there any tutorial how to install in on mattermost docker?
On the GitHub plugin site it says the server is inlcuded
This plugin contains both a server and web app portion.
so I don’t need to deploy the server docker GitHub - jitsi/docker-jitsi-meet: Jitsi Meet on Docker , do I?
