Mmctl export create fails with 'Limit exceeded for paging'
While trying to create an export, mmctl export create fails with:
exportAllPosts: Limit exceeded for paging., failed to find Posts
  1. On the Mattermost server, create an export:
    cd /opt/mattermost/
    bin/mmctl --local export create
  2. Check the logs:
    tail -f /opt/mattermost/logs/mattermost.log
Mattermost version 10.7.0
Expected behaviour
Create a full export of the server, including messages.
Observed behaviour
No user messages are in the resulting export. The file itself is only 8 kb.
The export job fails with:
{"timestamp":"2025-06-25 14:02:26.690 +01:00","level":"error","msg":"SimpleWorker: job execution error","caller":"jobs/base_workers.go:86","worker_name":"ExportProcess","job_id":"16444px4epretb4b37yeowqsga","job_type":"export_process","job_create_at":"Jun 25 13:02:19.193","error":"exportAllPosts: Limit exceeded for paging., failed to find Posts: Error 1305 (42000): FUNCTION mattermost.JSON_ARRAYAGG does not exist"}
Full log available in the bug report:
Hi @awky! Have you by any chance tried updating MySQL to see if that might fix the issue? Alternatively, I’d also recommend checking out this doc around software/hardware requirements to see if might help surface any additional clues: Software and hardware requirements - Mattermost documentation
Hello, thanks for the reply! Now I’m looking at the docs it looks like MariaDB is even less supported than MySQL (the reason for us starting this migration :grin:)
This is our MariaDB / MySQL version:
mysql --version
mysql  Ver 15.1 Distrib 10.3.39-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
And this is our Debian version:
cat /etc/issue
Debian GNU/Linux 10 \n \l
Do you recommend upgrading MySQL before attempting an export?
We’ve already got a functional Debian 12 + Postgres Mattermost ready to import. Cheers :slight_smile:
Thanks for the update, @awky! Given that MariaDB 10.3 is quite outdated and lacks support for JSON functions like JSON_ARRAYAGG, I’d definitely recommend completing the switch to MySQL 8+ or PostgreSQL before running the export. Sounds like your Debian 12 + Postgres setup is right on track! :blush:
Thanks for the help! Using a newer version of MariaDB solved my problem.
For the benefit of future readers:
The problem
MariaDB versions before 10.5.0 do no support JSON_ARRAYAGG [source]. This is required for mmctl export to work.
The solution
Temporarily switch Mattermost to a newer MariaDB. You could upgrade in-place, but that seemed dangerous to me.
Set up a new MariaDB server
I created a Debian 12 server, which is new enough to install MariaDB 10.11.11.
  1. Install MariaDB on a new server:
    # root@new-server
    apt update
    apt install mariadb-server
  2. Configure it to listen to remote connections: Edit /etc/mysql/mariadb.conf.d/50-server.cnf
      # Instead of skip-networking the default is now to listen only on
      # localhost which is more compatible and is not less secure.
    - bind-address            = 127.0.0.1
    + bind-address            = 0.0.0.0
  3. Restart MariaDB:
    service mariadb restart
  4. If using a firewall you might need to open the MariaDB port, for example:
    ufw allow 3306/tcp
    ufw reload
  5. Prepare the Mattermost database (you need to use the same DB user password as your original instance, replace ‘db_user_password’)
    # root@new-server
    mysql
    CREATE DATABASE mattermost;
    CREATE USER 'mattermost'@'%' IDENTIFIED BY 'db_user_password';
    GRANT ALL PRIVILEGES ON mattermost.* TO 'mattermost'@'%';
Copy the data across
  1. On the old server, perform a database dump:
    # root@old-server
    mysqldump mattermost > mattermost_dump.sql
  2. Copy the mattermost_dump.sql file to the new server.
  3. On the new server, restore the data:
    # Note: I'm logging in with the 'mattermost' database user and requesting a password
    # prompt with '-p'. This isn't strictly necessary ('mysql mattermost' would work) but
    # it's a nice test that the user has the right permissions.
    cat mattermost_dump.sql | mysql -u mattermost -p mattermost
Switch Mattermost to the new MariaDB server
  1. On the old server, edit the Mattermost config /opt/mattermost/config/config.json – replacing ‘db_user_password’ and ‘my_db_ip_address’.
    "SqlSettings": {
        "DriverName": "mysql",
    -   "DataSource": "mattermost:db_user_password@tcp(localhost:58103)/mattermost?charset=utf8mb4,utf8\u0026readTimeout=30s\u0026writeTimeout=30s",
    +   "DataSource": "mattermost:db_user_password@tcp(my_db_ip_address:58103)/mattermost?charset=utf8mb4,utf8\u0026readTimeout=30s\u0026writeTimeout=30s",
        "DataSourceReplicas": [],
  2. Restart Mattermost:
    service mattermost restart
Final result
At this point your set up looks like this:
And you are free to run mmctl export create :slight_smile:
