Nethserver 8 Installation mattermost adding plugins Focalboard
I am trying to install focalboard plugin into Nethserver App Mattermost, I succesfully add plugin but when I try to enable to Plugin Management this is the error “This plugin failed to start. unable to generate webapp bundle: focalboard: unable to remove old webapp bundle directory: client/plugins/focalboard: open client/plugins: permission denied”
Anyone workaround ?
That sounds like a permissions issue on the server. Do you have root access, or is it hosted by someone else?
this is hosted in the Nethserver , I am not really familiar with allowing permissions.
I do not know what a Nethserver is. I’m guessing you’ll need to open a support case with them.
