hello
i deployed matermost on kubernetes with operator
i d like to configure the welcpome bot
so i create a config map with the config.json
and in my installation i put a mountpath for this file :
volumeMounts:
- name: welcome
mountPath: /mattermost/plugins/com.mattermost.welcomebot/plugin.json
subPath: plugin.json
volumes:
- name: welcome
configMap:
items:
- key: plugin.json
path: plugin.json
it works , the file is mounted but when i deploy it i go this error
{“timestamp”:“2022-05-23 12:00:50.372 Z”,“level”:“error”,“msg”:“Unable to move plugin from temporary directory to final destination. Another plugin may be using the same directory name.”,“caller”:“web/context.go:105”,“path”:"/api/v4/plugins/marketplace",“request_id”:“53rw596ctpf3pqrqpqhfqu1gha”,“ip_addr”:",“user_id”:“jei45ycqufr55gd7usqknyyoio”,“method”:“POST”,“err_where”:“installExtractedPlugin”,“http_code”:500,“err_details”:“destination already exists”}
Hi @sarce666, thanks for bringing this to our attention! I checked with some of our engineers (here’s the conversation) and this appears to be a known problem, and isn’t something we have plans to support.
However, you should be able to work around this issue with mmctl which has a config
command to get and set configurations for Mattermost and any plugins you have installed.
For example, you can use the command mmctl config get PluginSettings.Plugins.com.mattermost.welcomebot
to get welcomebot’s current configuration and change “get” to “set” to modify it. Here’s some more info about the config command.
Let me know if this solves your issue.
thanks
but how to sent this command in the first installation yaml file:
apiVersion: installation.mattermost.com/v1beta1
kind: Mattermost
command is not recognize there
If I understand your question, you’re asking how to do this when you first install Mattermost? If so, you should be able to do it by installing mmctl to any host that is capable of communicating with your Kubernetes cluster. You can then trigger the mmctl command manually or automate it with a bash script or something similar.
hello
this is a bit what i though , but i would prefer an automate possibilities in the deployment
that means if i redeploy or one of my pods restart i lose everyhting and i have to do it manually
so i loose all the good point of kubernetes
or is there a way to have the the /mattermost/plugins in presistence mode so i keep it when restarting my pods
i dont see any options in the spec in the orchestrator either ?
thanks
@sarce666 I did some investigation and came across this possible answer. Does this help with your problem?
hello ben
ut , when I start my deployment , my mattermost pods is created with a random name :
db-523050-mysql-0 4/4 Running 2 (6d19h ago) 6d19h
metis-64797d5b58-qbqs2 1/1 Running 0 6d19h
in my exemple it is metis-64797d5b58-qbqs2
so how can I put this info in the initial deployement as it does not yet know it ?
as far as I understand you want me to send the mmtcl command in the mattermost pod ?
kind: Mattermost
metadata:
name: metis # Chose the desired name
spec:
size: 100users # Adjust to your requirements
ingress:
enabled: true
host: metis.cyberpeaceinstitute.org # Adjust to your domain
annotations:
kubernetes.io/ingress.class: nginx
version: 6.6.1
licenseSecret: “mattermost-license4”
apiVersion: v1
kind: Pod
metadata:
labels:
app: mattermost
purpose: mmctl
spec:
containers:
- name: mattermost
image: mattermost/mattermost-enterprise-edition:6.6.1
command: [“mmctl config get PluginSettings.Plugins.com.mattermost.welcomebot”]
another issue
if i launch the command on a starting pod i have this error after i auth
I got this
~ $ mmctl config get PluginSettings.Plugins.com.mattermost.welcomebot
WARNING: server version 6.6.1.6.6.1.8827b6decd348d2ef39d811cc0178d32.true doesn’t match mmctl version
Error: invalid key
