PostgreSQL connection error while Slack import
Hi!
I’m using team edition self-hosted in docker container.
I’m trying to import Slack export, it’s kinda huge(jsonl file uncompressed is ~7G):
Users 691
Posts 6483790
Direct Channels 5642
Direct Posts 1786848
That’s without attachments (which I will try later, there are around 130G of them).
I’ve already edited “long profile description” and two strange channels duplicates (renamed to channelname2 (including user channel-members).
Import of users - successful. Channels incl. private - successful. Some of messages (850k) - also successful.
But then it throws an error(from mattermost container, and the same in job description):
{"timestamp":"2024-09-09 11:41:43.470 Z","level":"error","msg":"SimpleWorker: job execution error","caller":"jobs/base_workers.go:96","worker_name":"ImportProcess","job_id":"tq14i45mtiffmykyy9usih84ko","job_type":"import_process","job_create_at":"Sep  9 11:22:42.309","error":"importMultiplePostLines: Unable to save the Post., failed to save Post: pq: canceling statement due to user request"}
That error from postgres container:
2024-09-09 14:19:11.762 UTC [48] DETAIL:  parameters: $1 = '1725902351761', $2 = 'error', $3 = '{"error": "Error during job execution. — importMultiplePostLines: Unable to overwrite the Post., MError:\nfailed to update Post with id=rf1yk4x9i7rmmd8r9pa3obsd3w: pq: canceling statement due to user request\ndriver: bad connection\n2 errors total.\n", "local_mode": "false", "import_file": "d1kros96wbf9jqgcyqm87xbtfy_mm_double.zip", "line_number": "488542", "extract_content": "true"}', $4 = '-1', $5 = '9quky6wyn3rhujancrzcrsf1zc', $6 = 'in_progress'
I’ve tried to increase VM resources (10cpu, 10g ram) - during the import load average rise to [8-10, ram usage just to 2-3gb.
I’ve tried to increase postgres connection timeout (600s), but I haven’t seen long sessions in postgres before the error.
What could I do else? Where to look, how to troubleshoot more? Any ideas?
What version of Mattermost are you on? We still see people on 5.x or 7.x, and the tooling around this sort of functionality has steadily improved.
Something fresh: mattermost/mattermost-team-edition:9.9.1
You could try Mattermost
