PRTG to Mattermost
Dear Colleagues,
Can you share with me any manual for sending alerts from PRTG to Mattermost?
Alternative as TelegramBOT.
Thank you.
Hi @kajafarov and welcome to the Mattermost forums!
Mattermost webhooks are compatible to Slack webhooks, so you can just use the “Send Slack Message” option in your PRTG notification template. Paste the URL for the incoming webhook you created first in the Mattermost “integrations” section and then try to send a test message:
The default notification will look like this (placeholders would be replaced by PRTG in the case of a real event):
Thank you. Just one question. I created webhook and create chanel. But got all notification as my user bot. How i can change notification user ?
