ssmok
(Nikita)
1
Hello.
I installed Mattermost via Docker using the included NGINX. Everything works fine except for the push notifications on mobile phone.
When I log in on my phone, I see this warning message:
Push notification settings:
Log messages:
{"timestamp":"2024-01-26 05:32:41.450 Z","level":"info","msg":"Notification will be sent","caller":"app/notification_push.go:444","logSource":"notifications","ackId":"r3tqjj9cj7g7dewas4t68qot5o","type":"clear","userId":"qdnnmzxdhp893d1f5qnemu8gqw","postId":"","status":"Prepared to send"}
{"timestamp":"2024-01-26 05:32:44.572 Z","level":"error","msg":"Notification error","caller":"app/notification_push.go:131","logSource":"notifications","ackId":"r3tqjj9cj7g7dewas4t68qot5o","type":"clear","userId":"qdnnmzxdhp893d1f5qnemu8gqw","postId":"","channelId":"iwqubkh5pfgmzq1gqzoxi87t3o","deviceId":"651fc0d8dc96f93723beb662f7d379a07ee18cb717f5cb0ec6f38c78271578c1","status":"Post \"https://push-test.mattermost.com/api/v1/send_push\": net/http: TLS handshake timeout"}
Please tell me what I have to do to make it work properly. Thank you!
ssmok
(Nikita)
3
Thank you. Documentation didn’t help.
I ran this script in container shell and didn’t get any response
curl https://push-test.mattermost.com
ssmok
(Nikita)
4
ran this command:
sudo docker exec -ti c9ffed7a844e curl -v https://push-test.mattermost.com
answer:
* Trying 3.94.16.185:443...
* Connected to push-test.mattermost.com (3.94.16.185) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* OpenSSL SSL_connect: Connection reset by peer in connection to push-test.mattermost.com:443
* Closing connection 0
* TLSv1.0 (OUT), TLS header, Unknown (21):
* TLSv1.3 (OUT), TLS alert, decode error (562):
curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to push-test.mattermost.com:443
Сan someone help?
What does openssl s_client -showcerts -connect push-test.mattermost.com:443 </dev/null return?
ssmok
(Nikita)
6
ran this command in mattermost docker container:
sudo docker exec -it 36b3066f6195 openssl s_client -showcerts -connect push-test.mattermost.com:443
output:
CONNECTED(00000003)
and nothing else…
Hi, did you end up solving this issue?
