I have a VPS server with Ionos and tried installing Mattermost omnibus. I keep running into the same issue below. Any help would be much appreciated!
fatal: [localhost]: FAILED! => {“changed”: false, “msg”: “Unable to start service nginx: Job for nginx.service failed because the control process exited with error code.\nSee "systemctl status nginx.service" and "journalctl -xeu nginx.service" for details.\n”}
Hi @john.oliver I ended up reinstalling ubuntu fresh on the server to get rid of Plesk, so I can install Mattermost straight away. it worked, but I’m unable to get to the server interface so far (using an IP address, no domain)
Jan 22 15:52:10 ubuntu systemd[1]: Failed to start Mattermost.
░░ Support: Enterprise open source support | Ubuntu
░░ Automatic restarting of the unit mattermost.service has been scheduled, as the result for
░░ the configured Restart= setting for the unit.
Jan 22 15:52:41 ubuntu systemd[1]: Stopped Mattermost.
░░ Subject: A stop job for unit mattermost.service has finished
░░ Defined-By: systemd
░░ A stop job for unit mattermost.service has finished.
░░ The job identifier is 25247 and the job result is done.
Jan 22 15:52:41 ubuntu systemd[1]: mattermost.service: Failed to load environment files: No such file or directory
Jan 22 15:52:41 ubuntu systemd[1]: mattermost.service: Failed to run ‘start’ task: No such file or directory
Jan 22 15:52:41 ubuntu systemd[1]: mattermost.service: Failed with result ‘resources’.
░░ Subject: Unit failed
░░ The unit mattermost.service has entered the ‘failed’ state with result ‘resources’.
Jan 22 15:52:41 ubuntu systemd[1]: Failed to start Mattermost.
░░ Subject: A start job for unit mattermost.service has failed
░░ A start job for unit mattermost.service has finished with a failure.
░░ The job identifier is 25247 and the job result is failed.
Jan 22 15:52:51 ubuntu systemd[1]: mattermost.service: Scheduled restart job, restart counter is at 268.
░░ Subject: Automatic restarting of a unit has been scheduled
Jan 22 15:52:51 ubuntu systemd[1]: Stopped Mattermost.
░░ The job identifier is 25339 and the job result is done.
Jan 22 15:52:51 ubuntu systemd[1]: mattermost.service: Failed to load environment files: No such file or directory
Jan 22 15:52:51 ubuntu systemd[1]: mattermost.service: Failed to run ‘start’ task: No such file or directory
Jan 22 15:52:51 ubuntu systemd[1]: mattermost.service: Failed with result ‘resources’.
Jan 22 15:52:51 ubuntu systemd[1]: Failed to start Mattermost.
░░ The job identifier is 25339 and the job result is failed.
@john.oliver thank you for your help. I don’t know how to do either of these things, a true newbie :). Thanks in advance for any advice/guidance you can provide to perform these checks
Look at the contents of ExecStart and WorkingDirectory. Do an ‘ls -lZ’ on each. Make sure they match what’s on your system, that ExecStart is the mattermost binary with execute permissions and that WorkingDirectory is a valid directory that the mattermost user can read and write into.
@john.oliver happy to report I fixed it in a rather unrefined manner: I re-installed Linux on the server from scratch and ran the omnibus install again. I believe the core of my issue was that I tried installing Mattermost omnibus after a partially failed attempt at a prior Mattermost install. Some files must have been in conflict. Thanks a lot for your help!
