[Solved] Bleve never finish indexing (stuck in 96% always)
Bleve never ends indexing… always stuck in 96% forever… never ends.
Using currently community 10.4.2 but happened in this installation since older versions…
Really don’t know what to do… nothing relevant on logs…
Just enable Bleve, purge indexes, and start to index once again… always the same result.
Tried even to disable Bleve, remove everything under “IndexDir” directory, enable it once again and try a new index… same result.
Just to finish indexing :wink:
Add screenshot
Had similar behavior on bleve reindex. In my case running under docker with limited memory.
Problem detected was reindexing process goes out of memory.
Solved adding on config.json property "BatchSize": 1000 on "BleveSettings" section
It takes some more time in exchange of less resource.
Try finding your own value to adjust rate speed/resources
That was it!!!
Thanks so much for helping me… you were so kind to share your experience. It seemed a difficult problem without loglines or any other… much clever for your part :slight_smile:
Woo hoo! Thanks @ealonso for helping out with the solution!
