[SOLVED] Bridge Mattermost/Slack with "filters"?
I would like to use mattermost on my company. But to keep talking with external partners, i was thinking about sync channel in mattermost with slack. What is the best way to do it?
Do you think we can filters the sync? (to keep confidential data in mattermost)
Examples:
  • don’t export picture from mattermost to slack
  • detect thats an IP is written in mattermost, remplace it xx.xx.xx.xx in slack?
Thanks in advance for your answers!
Regards,
Yoann
Hi @fobyy
Thank you for your question!
We don’t think anyone has built a bridge for Slack yet. There is an IRC bridge if you’d like to look at how it was done there?
Thanks for your response, i’ll check IRC bridge then!
