Hello
I have set up the complete environment for load test according to the links provided below:
When I run the loadtest all command I get the following error in UI console
[INFO] Done starting entities
│[INFO] Test set to run for 20 minutes
│[ERROR] Internal error - code should not reach this point: goroutine 251 [running]:
runtime/debug.Stack(0xc42021b448, 0xa660a0, 0xc42012ba00)
Internal error - code should not reach this point: goroutine 220195 [running]:
│runtime/debug.Stack(0xc42021b448, 0xa660a0, 0xc4203171c0)
│/usr/local/go/src/runtime/debug/stack.go:24 +0x79
│github.com/mattermost/mattermost-load-test/loadtest.doStatusPolling.func1(0xc4203cc000)
│/usr/local/go/src/github.com/mattermost/mattermost-load-test/loadtest/entity.go:68 +0x57
│panic(0xa660a0, 0xc4203171c0)
│/usr/local/go/src/runtime/panic.go:489 +0x2cf
│github.com/mattermost/mattermost-load-test/autocreation.*UserImportData).PickTeamChannel(0xc4203c
│c030, 0xc4201dad50, 0xc42021b640)
/usr/local/go/src/github.com/mattermost/mattermost-load-test/autocreation/bulkload.go:137 +0x1b1
And then the UI exits and displays this:
[INFO] Stopping monitor routines. Timeout is 10 seconds.
[INFO]
--------- Loadtest Report ------------
Score: NaN
[INFO] DONE!
Screenshot for same- https://www.screencast.com/t/My0Rhnx62oZh
Can someone guide what could be wrong.
