[Solved] Problem with push server `err=crypto/tls: failed to parse certificate PEM data`
Hi there,
we have set up a mattermost server and a server for the push-service. We followed the documentation, but when we try to fire up a push-message like this:
curl http://127.0.0.1:8066/api/v1/send_push -X POST -H “Content-Type: application/json” -d ‘{ “message”:“test”, “badge”: 1, “platform”:“apple”, “server_id”:“de.xxxxxxx.Mattermost”, “device_id”:“000000000000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF”}’
the log shows this error message:
ERROR Failed to send apple push sid=de.xxxxxxx.Mattermost did=000000000000000000000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF err=crypto/tls: failed to parse certificate PEM data
The Push config:
    "ListenAddress": ":8066",
    "ApplePushServer": "gateway.push.apple.com:2195",
    "ApplePushCertPublic": "/opt/matterpush/bin/MattermostPushPrivatePem_new.pem",
    "ApplePushCertPrivate": "/opt/matterpush/bin/MattermostPushPrivatePem_new.pem",
    "ThrottlePerSec": 100,
    "ThrottleMemoryStoreSize": 10000,
    "ThrottleVaryByHeader": "X-Forwarded-For"
We verified the certificate ok:
root@08786a57720f:/opt/matterpush/bin# openssl verify MattermostPushPrivatePem_new.pem
MattermostPushPrivatePem_new.pem: OK
Any ideas?
Thanks,
Patric
The public and private cert files look like they are the same file? typically the public cert is something like publickey.cer and the private one is privatekey.pem
thanks for the quick answer, but this was one of our desperate moves to get the server running.
At first, we tried to use separate files, but later, we created a *.pem with both keys in it just to give it a try.
But the error message is always the same, even if you use filenames that don’t exist!
any other hints?
Patric
@pstiffel Have you checked that your push-proxy is running under a user that can read the files correctly and that your file/folder permissions are correct?
There should also be one key per file, one for public and one for private I don’t believe they should be combined.
Hi there,
we double-checked the permissions. The push-proxy is running in a container as root-user, and the certs belong to the root-user, so there shouldn’t be any permission problems…
Any other hints?
Patric
After checking with the latest version of the push server, the certificate errors are gone :facepalm:
Thanks to all for their effort.
Patric
