Ubuntu 16.04
postgresql
Mattermost 4.2.0
NginX
is my system. I complated the this guide but Mattermost don’t start automaticly. It just start after sudo -u mattermost ./platform and if I close my ssh connection, I’ll see 504 Gateway Time-out.
Thx
Hello @eicecek,
Thanks for your feedback,
The mattermost-platform repo was recently split into mattermost-server and mattermost-webapp repositories. I’m not sure whether this has anything to do with your command failing with sudo -u mattermost ./platform ?
Maybe this documentation will be helpful?
Did you follow “Setup Mattermost to use systemd for starting and stopping.” ???
after doing that, i don’t have any problems (same environment!).
- start at boot will work,
- sudo systemctl service mattermost start/stop/status is working too.
and try to get it working without nginx at first.
walter
I guess I skipped something without paying attention. Now, I have different problems
I’ll open another question, thanx for help.
