Can anyone point me in the direction of how to upgrade from 3.2. to 3.3 when using docker?
At the moment the only documentation I can find is here
But I’m wondering if this still applies or if there is something better I can follow?
Yes, i am also looking for same steps in docker. Appreciate if anyone help on this?
That guide worked for me except “docker-compose run app -upgrade_db_30” should be skipped.
Beforehand, I backed up the volumes folder into /tmp and committed the app and db containers to new image files.
Thanks for your detail. Let me try it. Will share the results. One question, what if you re-build with out commit the app and db containers as a new image files. Will it create a problem?
I tired zephyrweb steps, it is working fine. Thanks
