Is there a guide how to upgrade a Docker instance (using Team edition)? I see changes in the database, so I assume that some data conversion or script needs to be executed in order to change the database?
Or are your docker containers that awesome that automatically do these updates?
I noticed that the DB docker definition only creates the database, so this leads me to believe that the app docker takes care of creating/updating the schema?
It should be update automatically when you start the 3.6 container, it may take a couple of minutes depending on how big your database is, but as I said it should be pretty straight forward.
do you mean that we can install the latest docker and then it will upgrade our existing 3.4 container?
i tried that and it didn’t work.
when we launched our existing container, it is still 3.4.
we don’t want to lose our contents.
we got this error:
docker: Error response from daemon: Conflict. The container name “/mattermost-preview” is already in use by container 3c9a868d7433991cfa9f9b3d0a9dd6314c921759e8451026c80aa3aac7a02e28. You have to remove (or rename) that container to be able to reuse that name…
when running this
docker run --name mattermost-preview -d --publish 8065:8065 mattermost/mattermost-preview
Hi @functioneer
It seems like you’re running the preview version and without storing the data in a separate volume. So all the data is inside. If you remove it the container you’ll lose all of your data.
If this is indeed a preview and the data doesn’t matter then proceed here:
That’s Docker telling you that a container for that image already exists. Do this to remove the container, so that it creates the new container with the new image when you run the specified command (so run this first):
docker rm mattermost-preview
Now, if you have data, you need to rescue it from inside the container and save it somewhere else. Containers store their volume data inside /var folder (a really long folder name).
See here for more details about volumes https://docs.docker.com/engine/tutorials/dockervolumes/
There’s an explanation of the command docker inspect <name of your container> which can tell you where your data is located. So my advice will be to use that, get the volume where the data is being saved, copy it to another folder, then run the preview image (create a separate container, with a different name) but this time mount the volume to that folder (where you copied the files earlier) and see if your data is there.
Let me know how it goes!
