Hello!
Our company uses SSL client-side authentication to connect to internal resources externally (via Nginx). We’ve tested it with MatterMost and it works fine with browser (as in, it asks for necessary certificate), but the mobile apps don’t work, they just return “unable to connect” error.
Is there a way to implement this kind of authentication for MatterMost correctly or is it a feature that has to be requested (if it’s not on the roadmap already)?
Thanks in advance!
Hi @TeosVerdi,
Thanks for your question,
The feature is not yet implemented on mobile. You and your colleagues can add your vote to the feature request here which will increase it’s popularity.
