Stocks Alerts to Channel (over Webhooks?)
HI, i am searching something, which can tracks stocks and if they drop X% then an Alert will be posted into Mattermost Channel.
Does anyone has an Idea how i can archive this?
Hi @alorson,
Webhooks are the best way but you could also create a plugin for this - instructions here on how to get started: https://developers.mattermost.com/integrate/getting-started/.
You might also find an existing plugin on our Integrations directory that might work in your case: https://integrations.mattermost.com/. One example is Jenkins: https://integrations.mattermost.com/jenkins-plugin/.
Hi, uhm didn’t found anything usefull and i must confess that i don’t understand Jenkins at all. I went few times to their Product Page…
But i found something which could make this a whole lot easier:
MAIL to CHANNEL would solve many Problems and would be awesome. But Plugin can’t be installed because “Error: Konnte Manifest des extrahierten Plugins nicht abrufen”
besides, even the Matterpoll Plugin is not working correct.
So at the Moment i tried to install two Plugins and both not working or are buggy. :smiley: …
CLean and Fresh Mattermost Server (over docker) and Plugin installation is already allowed in config.
Any Ideas?
Hi @alorson, thank you for letting us know,
Would you be open to helping with the following additional information:
  • Your Mattermost server version
  • Full Mattermost logs
  • Plugin settings in the System console
