the trouble with TPNS: dial tcp: i/o timeout and it sometimes worked sometimes failed…
server env: GitHub - mattermost/mattermost-docker: Dockerfile for mattermost in production
Mattermost Team Edition
(Ver. E0)
Mattermost Version: 5.31.6{PATCH}
Database Schema Version: 5.30.0
Database: postgres -
User A text in the channel X
User B in channel X always gets a notification on the mobile app.
(no mute)
The mobile app (ios) does not get notifications sometimes.
Log
- notification log:
{"level":"error","ts":1651019827.0948913,"caller":"app/notification_push.go:106","msg":"Notification error","logSource":"notifications","ackId":"suwiwafk7jr8pyjwxojdyz8u3r","type":"message","userId":"ojdukremsjgnbbduk5uodnha1w","postId":"6chphxr367g6dnapu5xqpsud3o","channelId":"fs9x5bgnkfd5bkkgk3bcj6pgtr","deviceId":"b3716ca1306b061d5b9d09c96f9e66e49cd80aa7f0a8e9e4577894d81d66de25","status":"Post \"https://push-test.mattermost.com/api/v1/send_push\\": dial tcp: i/o timeout"}
- network test(curl) in mattermost_app_1 container:
/mattermost # curl -v https://push-test.mattermost.com/api/v1/send_push
* Trying 52.207.18.93:443...
* TCP_NODELAY set
* Connected to push-test.mattermost.com (52.207.18.93) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: /etc/ssl/certs/ca-certificates.crt
CApath: none
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* TLSv1.3 (IN), TLS handshake, Server hello (2):
* TLSv1.2 (IN), TLS handshake, Certificate (11):
* TLSv1.2 (IN), TLS handshake, Server key exchange (12):
* TLSv1.2 (IN), TLS handshake, Server finished (14):
* TLSv1.2 (OUT), TLS handshake, Client key exchange (16):
* TLSv1.2 (OUT), TLS change cipher, Change cipher spec (1):
* TLSv1.2 (OUT), TLS handshake, Finished (20):
* TLSv1.2 (IN), TLS handshake, Finished (20):
* SSL connection using TLSv1.2 / ECDHE-RSA-AES128-GCM-SHA256
* ALPN, server accepted to use h2
* Server certificate:
* subject: CN=*.mattermost.com
* start date: Dec 3 00:00:00 2021 GMT
* expire date: Dec 30 23:59:59 2022 GMT
* subjectAltName: host "push-test.mattermost.com" matched cert's "*.mattermost.com"
* issuer: C=US; O=Amazon; OU=Server CA 1B; CN=Amazon
* SSL certificate verify ok.
* Using HTTP2, server supports multi-use
* Connection state changed (HTTP/2 confirmed)
* Copying HTTP/2 data in stream buffer to connection buffer after upgrade: len=0
* Using Stream ID: 1 (easy handle 0x55b26bcb3580)
> GET /api/v1/send_push HTTP/2
> Host: push-test.mattermost.com
> User-Agent: curl/7.66.0
> Accept: */*
* Connection state changed (MAX_CONCURRENT_STREAMS == 128)!
< HTTP/2 405
< date: Wed, 27 Apr 2022 07:09:54 GMT
< content-length: 0
< x-ratelimit-limit: 300
< x-ratelimit-remaining: 299
< x-ratelimit-reset: 1
* Connection #0 to host push-test.mattermost.com left intact
/mattermost # curl -l https://push-test.mattermost.com/api/v1/send_push
* Trying 3.224.61.240:443...
* TCP_NODELAY set
* Connected to push-test.mattermost.com (3.224.61.240) port 443 (#0)
* ALPN, offering h2
CApath: none
* Using Stream ID: 1 (easy handle 0x56182a93a580)
> Accept: */*
< HTTP/2 405
< date: Wed, 27 Apr 2022 07:10:08 GMT
< content-length: 0
/mattermost #
