Threads show (1) red notification after all threads are read
Set in settings->display->collapsed reply threads to ON then read all threads
As is for all read channels it should show nothing (no number) next to threads and in icon panel Mattermost icon should not have a red (1) number
It shows (1) next to threads and in icon panel Mattermost icon has a red (1) number
Hi @geydu and welcome to the Mattermost forums!
This is a known issue with the current release and is already being investigated:
https://mattermost.atlassian.net/browse/MM-49519
Hi @agriesser,
Thanks for your prompt response.
Is there a workaround like finding that deleted thread and read it so that I will get rid of constant red (1) in my dock?
None that I’m aware of at the moment unfortunately, sorry. If I find out something, I’ll let you know!
I just clicked “Read all messages” and it’s gone. So my problem is solved.
Thanks.
That’s an interesting find - I read in some threads, that it did not help people to get the icon cleared, but maybe your situation was a bit different. Good to know, though and glad to hear you could fix it yourself!
