Issue in one concise sentence
Run mattermost container
Mattermost can connect to the BDD using TLS
I try to set up mattermost 7.5.2 with mysql BDD 8. I use a connexion string like this one
mysql://*USERNAME*:*PASSWORD*@tcp(*DB*:3306)/mattermost?&charset=utf8mb4,utf8&readTimeout=30s&writeTimeout=30s&tls=true
If I run the mattermost container there is the error I got :
Error: failed to load configuration: failed to initialize: driver: mysql, message: failed to grab connection to the database, command: grabbing_connection, originalError: x509: certificate signed by unknown authority, query:
I tried to use this connexion string (without tls)
mysql://*USERNAME*:*PASSWORD*@tcp(*DB*:3306)/mattermost?allowCleartextPasswords=true&charset=utf8mb4,utf8&readTimeout=30s&writeTimeout=30s&tls=false
It worked like that but I do not want to keep this unsecure configuration.
Do you have an idea why I have this issue ?
