totemcaf
(Carlos Fau)
1
Desktop client for Mac Os request “Please sign in using gitlab”
Install a MM server and configure to use GitLab login integration
Install the MacOS cliente
Open the application
Log in
The MM desktop logs me.
Desktop client rejects me and says “Please sign in using gitlab”.
I don’t know how to use GitLab to sign in to the MM desktop client.
amy.blais
(Amy Blais)
2
Hi @totemcaf!
Can you help take a look at this doc and send over the relevant environment details as well as any errors you’re seeing in logs / Console: https://docs.mattermost.com/process/support.html?
Can you also help with your config settings related to Gitlab: https://docs.mattermost.com/administration/config-settings.html#gitlab?
