Daichi
(Daichi Harada)
1
I tried to upgrade the version from 5.34.2 to 5.39.0.
I referred to it here.
https://docs.mattermost.com/upgrade/upgrading-mattermost-server.html
I ran step11 sudo systemctl start mattermost in the procedure.
However, Mattermost does not start and no response is returned.
What should I do?
Thank you.
syauqi_89
(Syauqi)
2
Hi @Daichi,
I understand that you are having issue starting up the server via system service.
Please do follow the steps to check if the system is actually running:
sudo systemctl status mattermost.service
If the service is not running, and the status is not failed, try running the following command to enable and start the system service:
sudo systemctl enable mattermost.service
sudo systemctl start mattermost.service
Hope this helps,
Please Let us know how it goes once you have run those command
