Boards problem in mattermost
I have problem with boards in mattermost. it is show “sorry, something went wrong”
as in photo below:
The log error is:
2023/06/15 08:53:16 [error] 64104#64104: *4033 open() “/usr/share/nginx/html/plugins/com.mattermost.nps/api/v1/connected” failed (2: No such file or directory), client: 10.10.106.23, server: 192.168.7.43, request: “POST /plugins/com.mattermost.nps/api/v1/connected HTTP/1.1”, host: “192.168.7.43”
my nginx.conf is:
server {
listen 80;
listen [::]:80;
server_name 192.168.7.43;
location /mattermost {
    proxy_pass http://127.0.0.1:8065;
my versions:
Ubuntu-22.04-server
nginx/1.18.0
PostgreSQL 14.8
Mattermost 7.10.2
Hi @abooor2 and welcome to the Mattermost forums!
Is this really your full nginx configuration? To me it looks like this is just a part of it and if I’d have to guess I’d say that your SiteUrl in Mattermost is not configured correctly. You seem to want to run mattermost in a subpath (which is not really a good idea, it causes several problems AFAIR), so f.ex. https://yourdomain.tld/mattermost and if you want to do that, you will also need to set this exact URL as the SiteUrl in Mattermost, otherwise the generated links will not be correct and might point to https://yourdomain.tld/something/something instead of https://yourdomain.tld/mattermost/something/something which could cause the errors you’re seeing then (nginx not proxying the request and trying to serve it from the local filesystem).
Yes that is all nginx configuration for mattermost
However, about the mattermost configuration siteURL
I set it already to http://192.168.7.43/mattermost but sorry I didn’t mention that in my question. So what do you think?
The reason that make me to use subpath becuase I want to use focalbord and mattermost on the same server so each application have to have its subpath
I make it as you suggested on the root path http://192.168.7.43 but boards still not working
The error log:
Jun 18 11:01:29 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:29.694 Z”,“level”:“warn”,“msg”:“Error while creating session for user access token”,“caller”:“app/session.go:90”,“error”:"createSessionForUserAccessToken: Inval>
Jun 18 11:01:29 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:29.694 Z”,“level”:“error”,“msg”:“no session token”,“caller”:“app/plugin_api.go:976”,“plugin_id”:“focalboard”}
Jun 18 11:01:29 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:29.695 Z”,“level”:“error”,“msg”:“no session token”,“caller”:“app/plugin_api.go:976”,“plugin_id”:“focalboard”}
Jun 18 11:01:29 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:29.697 Z”,“level”:“warn”,“msg”:“Error while creating session for user access token”,“caller”:“app/session.go:90”,“error”:"createSessionForUserAccessToken: Inval>
Jun 18 11:01:29 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:29.698 Z”,“level”:“error”,“msg”:“no session token”,“caller”:“app/plugin_api.go:976”,“plugin_id”:“focalboard”}
Jun 18 11:01:31 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:31.199 Z”,“level”:“warn”,“msg”:“Error while creating session for user access token”,“caller”:“app/session.go:90”,“error”:"createSessionForUserAccessToken: Inval>
Jun 18 11:01:31 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:31.200 Z”,“level”:“warn”,“msg”:“Error while creating session for user access token”,“caller”:“app/session.go:90”,“error”:"createSessionForUserAccessToken: Inval>
Jun 18 11:01:31 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:31.202 Z”,“level”:“error”,“msg”:“no session token”,“caller”:“app/plugin_api.go:976”,“plugin_id”:“focalboard”}
Jun 18 11:01:31 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:31.203 Z”,“level”:“warn”,“msg”:“Error while creating session for user access token”,“caller”:“app/session.go:90”,“error”:"createSessionForUserAccessToken: Inval>
Jun 18 11:01:31 mattermost mattermost[1021]: {“timestamp”:“2023-06-18 11:01:31.203 Z”,“level”:“error”,“msg”:“no session token”,“caller”:“app/plugin_api.go:976”,“plugin_id”:“focalboard”}
my nginx.conf:
server {
listen 80;
server_name server_ip;
location / {
    proxy_set_header X-Nginx-Proxy true;
    proxy_pass http://127.0.0.1:8065/;
    proxy_redirect off;
    # WebSocket support
    proxy_http_version 1.1;
my mattermost.json:
“ServiceSettings”: {
“SiteURL”: “http://192.168.7.43”,
“WebsocketURL”: “”,
“LicenseFileLocation”: “”,
“ListenAddress”: “:8065”,
“ConnectionSecurity”: “”,
“TLSCertFile”: “”,
“TLSKeyFile”: “”,
“TLSMinVer”: “1.2”,
“TLSStrictTransport”: false,
“TLSStrictTransportMaxAge”: 63072000,
“TLSOverwriteCiphers”: ,
“UseLetsEncrypt”: false,
“Forward80To443”: false,
“TrustedProxyIPHeader”: ,
“ReadTimeout”: 300,
“WriteTimeout”: 300,
“IdleTimeout”: 60,
“MaximumLoginAttempts”: 10,
“GoroutineHealthThreshold”: -1,
“EnableOAuthServiceProvider”: true,
“EnableIncomingWebhooks”: true,
“EnableOutgoingWebhooks”: true,
“EnableCommands”: true,
“EnablePostUsernameOverride”: false,
“EnablePostIconOverride”: false,
“GoogleDeveloperKey”: “”,
“EnableLinkPreviews”: true,
“EnablePermalinkPreviews”: true,
“RestrictLinkPreviews”: “”,
“EnableTesting”: false,
“EnableDeveloper”: false,
“DeveloperFlags”: “”,
“EnableClientPerformanceDebugging”: false,
“EnableOpenTracing”: false,
“EnableSecurityFixAlert”: true,
“EnableInsecureOutgoingConnections”: false,
“AllowedUntrustedInternalConnections”: “”,
“EnableMultifactorAuthentication”: false,
“EnforceMultifactorAuthentication”: false,
“EnableUserAccessTokens”: false,
“AllowCorsFrom”: “”,
“CorsExposedHeaders”: “”,
“CorsAllowCredentials”: false,
“CorsDebug”: false,
“AllowCookiesForSubdomains”: false,
“ExtendSessionLengthWithActivity”: true,
“SessionLengthWebInDays”: 30,
“SessionLengthWebInHours”: 720,
“SessionLengthMobileInDays”: 30,
“SessionLengthMobileInHours”: 720,
“SessionLengthSSOInDays”: 30,
“SessionLengthSSOInHours”: 720,
“SessionCacheInMinutes”: 10,
“SessionIdleTimeoutInMinutes”: 43200,
“WebsocketSecurePort”: 443,
“WebsocketPort”: 80,
“WebserverMode”: “gzip”,
“EnableGifPicker”: true,
“GfycatAPIKey”: “2_KtH_W5”,
“GfycatAPISecret”: “3wLVZPiswc3DnaiaFoLkDvB4X0IV6CpMkj4tf2inJRsBY6-FnkT08zGmppWFgeof”,
“EnableCustomEmoji”: true,
“EnableEmojiPicker”: true,
“PostEditTimeLimit”: -1,
“TimeBetweenUserTypingUpdatesMilliseconds”: 5000,
“EnablePostSearch”: true,
“EnableFileSearch”: true,
“MinimumHashtagLength”: 3,
“EnableUserTypingMessages”: true,
“EnableChannelViewedMessages”: true,
“EnableUserStatuses”: true,
“ExperimentalEnableAuthenticationTransfer”: true,
“ClusterLogTimeoutMilliseconds”: 2000,
“EnablePreviewFeatures”: true,
“EnableTutorial”: true,
“EnableOnboardingFlow”: true,
“ExperimentalEnableDefaultChannelLeaveJoinMessages”: true,
“ExperimentalGroupUnreadChannels”: “disabled”,
“EnableAPITeamDeletion”: false,
“EnableAPITriggerAdminNotifications”: false,
“EnableAPIUserDeletion”: false,
“ExperimentalEnableHardenedMode”: false,
“ExperimentalStrictCSRFEnforcement”: false,
“EnableEmailInvitations”: false,
“DisableBotsWhenOwnerIsDeactivated”: true,
“EnableBotAccountCreation”: false,
“EnableSVGs”: false,
“EnableLatex”: false,
“EnableInlineLatex”: true,
“PostPriority”: true,
“EnableAPIChannelDeletion”: false,
“EnableLocalMode”: false,
“LocalModeSocketLocation”: “/var/tmp/mattermost_local.socket”,
“EnableAWSMetering”: false,
“SplitKey”: “”,
“FeatureFlagSyncIntervalSeconds”: 30,
“DebugSplit”: false,
“ThreadAutoFollow”: true,
“CollapsedThreads”: “always_on”,
“ManagedResourcePaths”: “”,
“EnableCustomGroups”: true,
“SelfHostedPurchase”: true,
“AllowSyncedDrafts”: true,
“SelfHostedExpansion”: false
“TeamSettings”: {
“SiteName”: “Mattermost”,
“MaxUsersPerTeam”: 50,
“EnableUserCreation”: true,
“EnableOpenServer”: false,
“EnableUserDeactivation”: false,
“RestrictCreationToDomains”: “”,
“EnableCustomUserStatuses”: true,
“EnableCustomBrand”: false,
“CustomBrandText”: “”,
“CustomDescriptionText”: “”,
“RestrictDirectMessage”: “any”,
“EnableLastActiveTime”: true,
“UserStatusAwayTimeout”: 300,
“MaxChannelsPerTeam”: 2000,
“MaxNotificationsPerChannel”: 1000,
“EnableConfirmNotificationsToChannel”: true,
“TeammateNameDisplay”: “username”,
“ExperimentalViewArchivedChannels”: true,
“ExperimentalEnableAutomaticReplies”: false,
“LockTeammateNameDisplay”: false,
“ExperimentalPrimaryTeam”: “”,
“ExperimentalDefaultChannels”:
“ClientRequirements”: {
“AndroidLatestVersion”: “”,
“AndroidMinVersion”: “”,
“IosLatestVersion”: “”,
“IosMinVersion”: “”
“SqlSettings”: {
“DriverName”: “postgres”,
“DataSource”: “postgres://mmuser:mostest@localhost/mattermost?sslmode=disable\u0026connect_timeout=10\u0026binary_parameters=yes”,
“DataSourceReplicas”: ,
“DataSourceSearchReplicas”: ,
“MaxIdleConns”: 20,
“ConnMaxLifetimeMilliseconds”: 3600000,
“ConnMaxIdleTimeMilliseconds”: 300000,
“MaxOpenConns”: 300,
“Trace”: false,
“AtRestEncryptKey”: “5gheryd88y446yxjq4w5cqp34cmooc5h”,
“QueryTimeout”: 30,
“DisableDatabaseSearch”: false,
“MigrationsStatementTimeoutSeconds”: 100000,
“ReplicaLagSettings”:
“LogSettings”: {
“EnableConsole”: true,
“ConsoleLevel”: “INFO”,
“ConsoleJson”: true,
“EnableColor”: false,
“EnableFile”: true,
“FileLevel”: “INFO”,
“FileJson”: true,
“FileLocation”: “”,
“EnableWebhookDebugging”: true,
“EnableDiagnostics”: true,
“VerboseDiagnostics”: false,
“EnableSentry”: true,
“AdvancedLoggingConfig”: “”
“ExperimentalAuditSettings”: {
“FileEnabled”: false,
“FileName”: “”,
“FileMaxSizeMB”: 100,
“FileMaxAgeDays”: 0,
“FileMaxBackups”: 0,
“FileCompress”: false,
“FileMaxQueueSize”: 1000,
“NotificationLogSettings”: {
“EnableFile”: true,
“FileJson”: true,
“FileLocation”: “”,
“PasswordSettings”: {
“MinimumLength”: 8,
“Lowercase”: false,
“Number”: false,
“Uppercase”: false,
“Symbol”: false
“FileSettings”: {
“EnableFileAttachments”: true,
“EnableMobileUpload”: true,
“EnableMobileDownload”: true,
“MaxFileSize”: 104857600,
“MaxImageResolution”: 33177600,
“MaxImageDecoderConcurrency”: -1,
“DriverName”: “local”,
“Directory”: “./data/”,
“EnablePublicLink”: false,
“ExtractContent”: true,
“ArchiveRecursion”: false,
“PublicLinkSalt”: “dcpkc1cadzouhi8ak55im5ch4pq4a7nu”,
“InitialFont”: “nunito-bold.ttf”,
“AmazonS3AccessKeyId”: “”,
“AmazonS3SecretAccessKey”: “”,
“AmazonS3Bucket”: “”,
“AmazonS3PathPrefix”: “”,
“AmazonS3Region”: “”,
“AmazonS3Endpoint”: “s3.amazonaws.com”,
“AmazonS3SSL”: true,
“AmazonS3SignV2”: false,
“AmazonS3SSE”: false,
“AmazonS3Trace”: false,
“AmazonS3RequestTimeoutMilliseconds”: 30000
“EmailSettings”: {
“EnableSignUpWithEmail”: true,
“EnableSignInWithEmail”: true,
“EnableSignInWithUsername”: true,
“SendEmailNotifications”: false,
“UseChannelInEmailNotifications”: false,
“RequireEmailVerification”: false,
“FeedbackName”: “”,
“FeedbackEmail”: “”,
“ReplyToAddress”: “”,
“FeedbackOrganization”: “”,
“EnableSMTPAuth”: false,
“SMTPUsername”: “”,
“SMTPPassword”: “”,
“SMTPServer”: “localhost”,
“SMTPPort”: “10025”,
“SMTPServerTimeout”: 10,
“SendPushNotifications”: true,
“PushNotificationServer”: “https://push-test.mattermost.com”,
“PushNotificationContents”: “full”,
“PushNotificationBuffer”: 1000,
“EnableEmailBatching”: false,
“EmailBatchingBufferSize”: 256,
“EmailBatchingInterval”: 30,
“EnablePreviewModeBanner”: true,
“SkipServerCertificateVerification”: false,
“EmailNotificationContentsType”: “full”,
“LoginButtonColor”: “#0000”,
“LoginButtonBorderColor”: “#2389D7”,
“LoginButtonTextColor”: “#2389D7”,
“EnableInactivityEmail”: true
“RateLimitSettings”: {
“Enable”: false,
“PerSec”: 10,
“MaxBurst”: 100,
“MemoryStoreSize”: 10000,
“VaryByRemoteAddr”: true,
“VaryByUser”: false,
“VaryByHeader”: “”
“PrivacySettings”: {
“ShowEmailAddress”: true,
“ShowFullName”: true
“SupportSettings”: {
“TermsOfServiceLink”: “Terms of Use - Mattermost Open Source Collaboration Platform”,
“PrivacyPolicyLink”: “Mattermost Privacy Policy - Open Source Messaging”,
“AboutLink”: “https://docs.mattermost.com/about/product.html/”,
“HelpLink”: “Mattermost Documentation — Mattermost documentation”,
“ReportAProblemLink”: “How to contribute to Mattermost - Mattermost Handbook”,
“SupportEmail”: “”,
“CustomTermsOfServiceEnabled”: false,
“CustomTermsOfServiceReAcceptancePeriod”: 365,
“EnableAskCommunityLink”: true
“AnnouncementSettings”: {
“EnableBanner”: false,
“BannerText”: “”,
“BannerColor”: “#f2a93b”,
“BannerTextColor”: “#333333”,
“AllowBannerDismissal”: true,
“AdminNoticesEnabled”: true,
“UserNoticesEnabled”: true,
“NoticesURL”: “https://notices.mattermost.com/”,
“NoticesFetchFrequency”: 3600,
“NoticesSkipCache”: false
“ThemeSettings”: {
“EnableThemeSelection”: true,
“DefaultTheme”: “default”,
“AllowCustomThemes”: true,
“AllowedThemes”:
“GitLabSettings”: {
“Enable”: false,
“Secret”: “”,
“Id”: “”,
“Scope”: “”,
“AuthEndpoint”: “”,
“TokenEndpoint”: “”,
“UserAPIEndpoint”: “”,
“DiscoveryEndpoint”: “”,
“ButtonText”: “”,
“ButtonColor”: “”
“GoogleSettings”: {
“Enable”: false,
“Secret”: “”,
“Id”: “”,
“Scope”: “profile email”,
“AuthEndpoint”: “Sign in - Google Accounts”,
“TokenEndpoint”: “https://www.googleapis.com/oauth2/v4/token”,
“UserAPIEndpoint”: “https://people.googleapis.com/v1/people/me?personFields=names,emailAddresses,nicknames,metadata”,
“ButtonText”: “”,
“ButtonColor”: “”
“Office365Settings”: {
“Enable”: false,
“Secret”: “”,
“Id”: “”,
“Scope”: “User.Read”,
“AuthEndpoint”: “Sign in to your account”,
“TokenEndpoint”: “Sign in to your account”,
“UserAPIEndpoint”: “https://graph.microsoft.com/v1.0/me”,
“DirectoryId”: “”
“OpenIdSettings”: {
“Enable”: false,
“Secret”: “”,
“Id”: “”,
“Scope”: “profile openid email”,
“AuthEndpoint”: “”,
“ButtonText”: “”,
“ButtonColor”: “#145DBF”
“LdapSettings”: {
“Enable”: false,
“EnableSync”: false,
“LdapServer”: “”,
“LdapPort”: 389,
“BaseDN”: “”,
“BindUsername”: “”,
“BindPassword”: “”,
“UserFilter”: “”,
“GroupFilter”: “”,
“GuestFilter”: “”,
“EnableAdminFilter”: false,
“AdminFilter”: “”,
“GroupDisplayNameAttribute”: “”,
“GroupIdAttribute”: “”,
“FirstNameAttribute”: “”,
“LastNameAttribute”: “”,
“EmailAttribute”: “”,
“UsernameAttribute”: “”,
“NicknameAttribute”: “”,
“IdAttribute”: “”,
“PositionAttribute”: “”,
“LoginIdAttribute”: “”,
“PictureAttribute”: “”,
“SyncIntervalMinutes”: 60,
“SkipCertificateVerification”: false,
“PublicCertificateFile”: “”,
“PrivateKeyFile”: “”,
“QueryTimeout”: 60,
“MaxPageSize”: 0,
“LoginFieldName”: “”,
“Trace”: false
“ComplianceSettings”: {
“Enable”: false,
“EnableDaily”: false,
“BatchSize”: 30000
“LocalizationSettings”: {
“DefaultServerLocale”: “en”,
“DefaultClientLocale”: “en”,
“AvailableLocales”: “”
“SamlSettings”: {
“Enable”: false,
“EnableSyncWithLdap”: false,
“EnableSyncWithLdapIncludeAuth”: false,
“IgnoreGuestsLdapSync”: false,
“Verify”: true,
“Encrypt”: true,
“SignRequest”: false,
“IdpURL”: “”,
“IdpDescriptorURL”: “”,
“IdpMetadataURL”: “”,
“ServiceProviderIdentifier”: “”,
“AssertionConsumerServiceURL”: “”,
“SignatureAlgorithm”: “RSAwithSHA1”,
“CanonicalAlgorithm”: “Canonical1.0”,
“ScopingIDPProviderId”: “”,
“ScopingIDPName”: “”,
“IdpCertificateFile”: “”,
“IdAttribute”: “”,
“GuestAttribute”: “”,
“EnableAdminAttribute”: false,
“AdminAttribute”: “”,
“LocaleAttribute”: “”,
“LoginButtonText”: “SAML”,
“LoginButtonColor”: “#34a28b”,
“LoginButtonTextColor”: “#ffffff”
“NativeAppSettings”: {
“AppCustomURLSchemes”: [
“mmauth://”,
“mmauthbeta://”
“AppDownloadLink”: “Host Mattermost on Your Own Infrastructure”,
“AndroidAppDownloadLink”: “https://mattermost.com/mattermost-android-app/”,
“IosAppDownloadLink”: “‎Mattermost on the App Store”
“ClusterSettings”: {
“Enable”: false,
“ClusterName”: “”,
“OverrideHostname”: “”,
“NetworkInterface”: “”,
“BindAddress”: “”,
“AdvertiseAddress”: “”,
“UseIPAddress”: true,
“EnableGossipCompression”: true,
“EnableExperimentalGossipEncryption”: false,
“ReadOnlyConfig”: true,
“GossipPort”: 8074,
“StreamingPort”: 8075,
“MaxIdleConns”: 100,
“MaxIdleConnsPerHost”: 128,
“IdleConnTimeoutMilliseconds”: 90000
“MetricsSettings”: {
“Enable”: false,
“BlockProfileRate”: 0,
“ListenAddress”: “:8067”
“ExperimentalSettings”: {
“ClientSideCertEnable”: false,
“ClientSideCertCheck”: “secondary”,
“LinkMetadataTimeoutMilliseconds”: 5000,
“RestrictSystemAdmin”: false,
“UseNewSAMLLibrary”: false,
“EnableSharedChannels”: false,
“EnableRemoteClusterService”: false,
“EnableAppBar”: false,
“PatchPluginsReactDOM”: false
“AnalyticsSettings”: {
“MaxUsersForStatistics”: 2500
“ElasticsearchSettings”: {
“ConnectionURL”: “http://localhost:9200”,
“Username”: “elastic”,
“Password”: “changeme”,
“EnableIndexing”: false,
“EnableSearching”: false,
“EnableAutocomplete”: false,
“Sniff”: true,
“PostIndexReplicas”: 1,
“PostIndexShards”: 1,
“ChannelIndexReplicas”: 1,
“ChannelIndexShards”: 1,
“UserIndexReplicas”: 1,
“UserIndexShards”: 1,
“AggregatePostsAfterDays”: 365,
“PostsAggregatorJobStartTime”: “03:00”,
“IndexPrefix”: “”,
“LiveIndexingBatchSize”: 1,
“BatchSize”: 10000,
“RequestTimeoutSeconds”: 30,
“SkipTLSVerification”: false,
“CA”: “”,
“ClientCert”: “”,
“ClientKey”: “”,
“Trace”: “”
“BleveSettings”: {
“IndexDir”: “”,
“BatchSize”: 10000
“DataRetentionSettings”: {
“EnableMessageDeletion”: false,
“EnableFileDeletion”: false,
“EnableBoardsDeletion”: false,
“MessageRetentionDays”: 365,
“FileRetentionDays”: 365,
“BoardsRetentionDays”: 365,
“DeletionJobStartTime”: “02:00”,
“BatchSize”: 3000
“MessageExportSettings”: {
“EnableExport”: false,
“ExportFormat”: “actiance”,
“DailyRunTime”: “01:00”,
“ExportFromTimestamp”: 0,
“BatchSize”: 10000,
“DownloadExportResults”: false,
“GlobalRelaySettings”: {
“CustomerType”: “A9”,
“SMTPUsername”: “”,
“SMTPPassword”: “”,
“EmailAddress”: “”,
“SMTPServerTimeout”: 1800
“JobSettings”: {
“RunJobs”: true,
“RunScheduler”: true,
“CleanupJobsThresholdDays”: -1,
“CleanupConfigThresholdDays”: -1
“ProductSettings”: {
“EnablePublicSharedBoards”: false
“PluginSettings”: {
“Enable”: true,
“EnableUploads”: false,
“AllowInsecureDownloadURL”: false,
“EnableHealthCheck”: true,
“Directory”: “./plugins”,
“ClientDirectory”: “./client/plugins”,
“Plugins”: {
“focalboard”: {
“enablepublicsharedboards”: true
“playbooks”: {
“BotUserID”: “5yae89beh7fbjed8hyr4sb578r”
“PluginStates”: {
“com.mattermost.apps”: {
“Enable”: true
“com.mattermost.calls”: {
“Enable”: true
“com.mattermost.nps”: {
“Enable”: true
“com.mattermost.plugin-channel-export”: {
“Enable”: true
“focalboard”: {
“Enable”: true
“playbooks”: {
“Enable”: true
“EnableMarketplace”: true,
“EnableRemoteMarketplace”: true,
“AutomaticPrepackagedPlugins”: true,
“RequirePluginSignature”: false,
“MarketplaceURL”: “https://api.integrations.mattermost.com”,
“SignaturePublicKeyFiles”: ,
“ChimeraOAuthProxyURL”: “”
“DisplaySettings”: {
“CustomURLSchemes”: ,
“ExperimentalTimezone”: true
“GuestAccountsSettings”: {
“Enable”: false,
“AllowEmailAccounts”: true,
“ImageProxySettings”: {
“Enable”: false,
“ImageProxyType”: “local”,
“RemoteImageProxyURL”: “”,
“RemoteImageProxyOptions”: “”
“CloudSettings”: {
“CWSURL”: “https://customers.mattermost.com”,
“CWSAPIURL”: “https://portal.internal.prod.cloud.mattermost.com”
“ImportSettings”: {
“Directory”: “./import”,
“RetentionDays”: 30
“ExportSettings”: {
“Directory”: “./export”,
“RetentionDays”: 30
