The system console is divided in two panels. Left black panel is a menu and right white panel is the list of settings for the selected menu item. Both panels use scrolling to display their content outside the screen.
In iOS Safari, the right panel scroll doesn’t work. You can see a tiny scroll bar but scroll using touch doesn’t work. The left panel is fine.
Can we have a fix for this. I can’t use my ipad to change server settings. I’m forced to use a browser on my pc.
Mattermost Server 4.7.3
iOS 11.2.6
Cheers
Update:
Ticket created:
https://mattermost.atlassian.net/plugins/servlet/mobile#issue/MM-9991
