Mattermost iOS message render issue
Hi all,
Mattermost iOS : 1.20.0
iOS: 12.3.1
On the iPad when using scroll or display/hide keyboard, part of the message list is disappearing.
It looks like a render issue.
It’s also happening on iPhone.
Cheers
Normal:
Issue:
Also IPhone
Normal:
Issue:
@RbDev tried to clean up session caches?
yes I have. I actually reinstalled and the issue persists.
Hi @RbDev, we are working on a dot release for this, should be released in the next few days.
Hi @amy.blais,
This issue is incredible annoying. Is there a release date for the hotfix?
If not could you guys rollback to version 1.11 so that we have a functional mattermost in iOS until the fix is ready?
Cheers
Hi @RbDev, I’ll take a look if I can reproduce this, I thought this is related to missing messages issue that we fixed but the issue here seems a little different.
This issue is happening all the time.
Hi @RbDev, would you have reproduction steps to share?
@amy.blais that’s in the first post.
show/hide keyboard
switching channels
scrolling up and down.
Cool, I wasn’t able to reproduce this, so I’ll ask help from others.
@RbDev Would you be able to share any log errors or any errors you see when clicking “Report a Problem”?
Yes there is an error. I hope it helps.
Errors:
Date: Tue, 25 Jun 2019 19:38:48 GMT
Message: Received invalid response from the server.
Stack trace:
construct@[native code]
n@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:702:115542
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:904:1694
p@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:107:423
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:107:1740
n@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:107:898
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:107:1076
f@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:706:753
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:706:914
v@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:707:251
f@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:52:155
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:52:882
q@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:57:604
x@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:57:851
callImmediates@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:57:3156
callImmediates@[native code]
value@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:35:2823
/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:35:1196
value@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:35:2503
value@/var/containers/Bundle/Application/F9B05A4A-5709-49BC-B393-F10489149EC4/Mattermost.app/main.jsbundle:35:1166
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Date: Tue, 25 Jun 2019 19:39:03 GMT
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Date: Tue, 25 Jun 2019 19:39:11 GMT
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Date: Tue, 25 Jun 2019 19:39:15 GMT
Stack trace:
value@[native code]
value@[native code]
Date: Tue, 25 Jun 2019 19:39:20 GMT
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Date: Tue, 25 Jun 2019 19:40:57 GMT
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
Stack trace:
value@[native code]
value@[native code]
I have the same problem. But not always.
Hi @RbDev @JtheBAB
Sorry, I’m not able to reproduce this issue. You didn’t mention which server version you can reproduce this on (but looking at your other issues I decided to try on v5.12.3)
It’s iOS v1.24.0 now and this issue is still happening.
Part of the messages are not displayed causing a huge white gap in the app to appear.
Any chance someone will look into this?
