Config.json gets reset when using CLI on docker installation
config.json gets “reset” when using CLI on docker installation
We are able to run CLI commands !docker exec -it! as below but running it again causes alot of errors and then the config.json gets reset? and no longer contains our settings.
Running version:
docker@livm27p:/bin> docker exec -it mattermost-docker_app_1 mattermost version
Version: 5.30.0
Build Number: 5.31.0
Build Date: Fri Jan 15 02:36:16 UTC 2021
Build Enterprise Ready: true
DB Version: 5.31.0
that it is possible to do several CLI commands without error
Alot of errors and then missing all our settings in config.json
Thank you!
Kind regards,
Anette
Hello, @Anette
Would you mind confirming if you ran the CLI command using the root / mattermost user?
I just want to confirm if you might potentially run in a known issue here - Config.json resets itself to original if binary is run with root user starting from 5.30
Since you are running on 5.31.0, there is a chance that you might be affected by it.
