Like the title says, when I hit the
button I got that message from the calls bot.
I’ve searched in the System Console but I can’t find the option to enable that for all users.
Some guidance would be appreciated.
Thanks in advance.
Thanks in advance.
When I search “call” in the System Console as a System Administrator, I get “Calls (Beta)” as a search result under “PLUGINS”.
There, I can enable or disable the Calls Plugin.
Sadly, I’m getting Sorry, there was an error uploading that file. Please try again. when trying to upload a screenshot, here.
There is also this setting:
Enable on all channels
truefalse
When set to true, calls can be started in all channels where they’re not explicitly disabled.
the plugin is enabled but apparently not everyone can use the
Start call feature, except admins.
Yes, because they are disabled on all channels, by default. See my reply above.
I don’t have that option on the Calls plugin, though.
This is all I have:
Could you please go to the base view (where all the channels are) and take a screenshot of your instance’s About pop-up?
It’s all documented here.
https://docs.mattermost.com/configure/plugins-configuration-settings.html#test-mode
You need to disable Test Mode.
Gosh, I overlooked that one! That solves it. Thanks!!!
