Determine Number of Unread Messages
Hello.
I’m working with the Client4 and websocket portions of the mattermost-redux package to implement a custom client in React, and I’m trying to determine the correct “recipe” to find and maintain the number of unread messages in a given channel.
I’ve come across the Client4 getPostsSince method that lets me get the posts in a given channel since a given post ID. This seems like it might be a way to get the number of unread posts as longs as the last time the user viewed a specific channel is known. Is the information on when the user last viewed a channel available via the API?
Alternatively, is there a more effective way of determining and maintaining the number of unread messages per channel? Is there a “recipe” or tutorial covering this topic?
Hi Reggie, there’s a lot of guides on this over the web. Am not sure posting an external link is allowed or not. If yes kindly confirm me in the reply so I can give you a link to some guide to go forward with.
You’re most certainly allowed to post external links here!
@lengtmp can you post a link to a guide on how to do this?
Sure, check out the blog version of this, front contains the list of crap so do check out blog sections of any of these two:
  1. https://mycoles.vip/
  2. https://mythdhr.vip/
Hope this helps, thanks!
