DND dropdown menu outside browser boundaries
The dropdown menu, that should appear while hovering over “Do not disturb” is not showing up.
  • Login on your Mattermost Instance
  • Click on your profile picture in the top right corner
  • Hover over “Do not disturb”
Version is 10.2.0 Enterprise Edition, self hosted via Docker (Image mattermost/mattermost-enterprise-edition:10.2)
The issue is known for all users since at least september 2023 and affects the Desktop App as well as the webapp on Chrome and Firefox.
You should see a dropdown menu with “Clear after ”
Nothing shows up.
In the Inspector you can see the ally__popup Menu dropdown-menu SubMenu has style="visibility: hidden; top: 196px; right: 100%".
As the place it opens is already on the most-right, it will “show” the menu outside the boundary of the browser.
So if I change it in the inspector to style="visibility: hidden; top: 196px; right: auto" I can see the Dropdown Menu just fine.
The problem persists after the upgrade to version 10.5.1
Thank you @Scarlet for the reply.
I opened up an Issue on GitHub.
