An error similar to that described in https://github.com/mattermost/mattermost-developer-kit/issues/2 but there is no movement since November.
The installation runs without errors.
@danilvoe did you try making the change to index.js
that was suggested in the ticket that you linked? It may be a workaround worth pursuing until our developers get a change to fix the issue properly.
