How to connect Sentry 21 to Mattermost?
I set up with success Mattermost integration (incoming webhooks) with Sentry 9.1.2 : Sentry alert notification create a message in Mattermost channel.
Issue: after upgrade to Sentry 21, I don’t understand how to connect Sentry with Mattermost.
I didn’t find answer in these posts:
I found also this article: Sentry Issue Notifications via Mattermost Webhooks - Dan Monaghan
My understanding is that I need this webhook relay (translator) service to connect Sentry > version 9 to Mattermost.
Another approach : if « Mattermost incoming webhooks are Slack-compatible » then it maybe possible to connect Sentry Slack Integration to Mattermost, but I didn’t see where it is possible to change the webhook url :thinking:
Question: how do you connect Sentry to you Mattermost instance?
Best regards,
Stéphane
You can try to use https://github.com/Its-Alex/sentry-mattermost-sidecar too for Sentry Issues Alerts.
Cordially,
Alexandre.
