How to disable permission to modify channels by every user?
Any registered user can modify the channel
Im using the free version.
Any registered user can modify the channel as an Admin, i was trying to resolve that issue, but wih no success, sorry if that question were here before.
As admin i cannot change permission of any user to modify the channels, i don’t think that the Free version is the problem
Hi @adamfx,
When you say “modify the channel”, do you mean adding / removing users, editing the channel header, or renaming the channel?
Yes. Even archive the channel.
Hi @adamfx,
Depending on which server version you’re on, there are settings to restrict these permissions, but they are only available in Enterprise Edition.
Here are the settings:
