How to disable team creation by non System Admin
How do you disable team creation for non System Admins? I saw a note in the docs that says the config.json option was depcreated (even though it still exists in it) and that it was moved to the database and you should use the System Console to modify it, but I don’t see this option anywhere in the System Console
Using EE version 5.7.0
Hi @user2019,
Do you see Advanced Permissions section in the System Console: https://docs.mattermost.com/deployment/advanced-permissions.html? I believe the setting can be found there.
