How to enable ssl in a docker installation?
I have installed Mattermost with Docker following the One-line Docker Install. Amazing.
Now, is there a way to enable SSL (or maybe I should state HTTPS?) to protect the sessions to the server with encryption?
thank you
Gustavo.
hum, as stated in this post:
http://docs.mattermost.com/install/prod-ubuntu.html
We use Nginx for proxying request to the Mattermost Server. The main benefits are:
  • SSL termination
  • http to https redirect
  • Port mapping :80 to :8065
  • Standard request logs
I guess I need to check if the docker installation has Nginx in it.
The one-line Docker install is designed for only a preview, not production. Please see install guides and find the production Docker deployment created by the community as a starting point for what I believe you want to set up?
