How to extend search limit?
Hi there,
By default, search shows only 100 files and messages. How to extend this limit? Or load more search results.
Thanks!
Selection_072
Hi, @olodar
Can you please confirm which version of Mattermost Server and Mattermost desktop / mobile app you are running on so I can attempt to reproduce it on my side?
Also, What was the filter you applied when you performed the search?
Hi, @ahmaddanial, thanks for your reply!
Mattermost server version is 5.35.0 and desktop client is v4.6.2.
Any filter. For example, search with “MESSAGES” from:user shows only 100 messages. Same with files and other filters.
Hi, @olodar
Got it. I will test this on my end and get back to you on this. Thanks again for the clarification.
Hello again, @olodar
Verified that it is a feature that comes shipped together with 5.35.0:
@eric , may I know if there is any way for us to increase the search limit? Anything that can be changed from the mattermost-webapp side?
This limit is really trouble, because it is not allow find old files/messages.
