Hi everyone
i want to integrate veeam one with Mattermost, we want to send alarm to specific channel.
i need help
Hi everyone
i need help
Hello, @sevan
The Veeam + Mattermost integration developed by drupalbee that sends notification to channels was deprecated since 2018 - MattermostVeeamNotifications.
The newer version from MelonSmasher called Momentum on the other hand has yet to have support for Mattermost but it is in the roadmap. So, I suggest that you keep an eye on this github page.
thank you @ahmaddanial
i will check .
