Installing Mattermost in Elastic Beanstalk causes errors
Here is the details of the error:
Application deployment failed at 2019-12-24T13:02:30Z with exit status 1 and error: Hook /opt/elasticbeanstalk/hooks/appdeploy/enact/03start-task.sh failed.
  • . /opt/elasticbeanstalk/hooks/common.sh
  • RETRY=0
  • initctl start eb-ecs EB_EVENT_FILE=/tmp/eventsfile20191224-14898-8rj7zk
    initctl: Job failed to start
  • ‘[’ -f /etc/elasticbeanstalk/.eb-ecs-start-no-retry ‘]’
  • warn ‘Failed to start ECS task, retrying…’
  • echo ‘Failed to start ECS task, retrying…’
  • eventHelper.py --msg ‘Failed to start ECS task, retrying…’ --severity WARN
  • RETRY=1
  • sleep 3
  • ‘[’ 1 -gt 1 ‘]’
  • RETRY=2
  • sleep 3
  • ‘[’ 2 -gt 1 ‘]’
  • error_exit ‘Failed to start ECS task after retrying 2 times.’ 1
  • error ‘Failed to start ECS task after retrying 2 times.’
  • echo ‘Failed to start ECS task after retrying 2 times.’
  • eventHelper.py --msg ‘Failed to start ECS task after retrying 2 times.’ --severity ERROR
  • exit 1.
I used this for installation
https://raw.githubusercontent.com/mattermost/mattermost-docker/master/contrib/aws/Dockerrun.aws.json
Hey @karthik018 have you figured out on this issue?
I am facing exactly the same issue ‘ECS task stopped due to: Task failed to start. (web:’
