Would you be able to join our community server and send me through a DM the logs of the app?
The community server is https://community.mattermost.com . My handle over there is @daniel.espino-garcia . In order to get the logs of the app, hit your profile, settings, and report a problem.
Please share a description of the problem:
Current User Id:
Current Team Id:
Server Version: 9.9.0 (Build 9307585135)
App Version: 2.17.1 (Build 529)
App Platform: ios
Device Model: iPhone14,2
2024/06/30 00:50:36:407 DEBUG Setting the badge count based on database values to 0
2024/06/30 09:00:08:435 INFO websocket closed wss://domain.com/api/v4/websocket?connection_id=rand&sequence_number=2
2024/06/30 09:00:09:052 DEBUG Not updating badge count, since we have no mentions in the database, and the number of notifications in the notification center is 1
2024/06/30 09:00:10:064 DEBUG Updating a record with pending changes in table PostsInChannel
2024/06/30 09:00:10:160 DEBUG Trying to batch a record with no prepared state on table PostsInChannel
2024/07/01 00:26:57:732 INFO websocket re-established connection to wss://domain.com/api/v4/websocket?connection_id=rand2&sequence_number=1
2024/07/01 00:26:57:773 INFO wss://domain.com/api/v4/websocket?connection_id=rand2&sequence_number=1 got connection id randid
2024/07/01 00:26:57:773 INFO wss://domain.com/api/v4/websocket?connection_id=rand2&sequence_number=1 long timeout, or server restart, or sequence number is not found, or first connect after failure.
2024/07/01 00:26:58:355 INFO WEBSOCKET RECONNECT MODELS BATCHING TOOK 25ms
2024/07/01 00:26:59:142 DEBUG error on fetchBindings Received invalid response from the server.; JSON could not be serialized because of error:
The data cannot be read because it is not in the correct format.
2024/07/01 00:27:01:915 INFO Running "Settings
2024/07/01 00:27:03:493 INFO Running "SettingsAdvanced
2024/07/01 00:27:06:370 INFO Running "SettingsDisplay
2024/07/01 00:27:14:851 DEBUG Setting the badge count based on database values to 0
2024/07/01 00:27:41:244 INFO Launch app in Home screen
2024/07/01 00:27:41:377 INFO Running "Home
2024/07/01 00:27:42:313 DEBUG Not updating badge count, since we have no mentions in the database, and the number of notifications in the notification center is 1
2024/07/01 00:27:46:652 INFO websocket connecting to wss://domain.com/api/v4/websocket?connection_id=&sequence_number=0
2024/07/01 00:27:46:761 INFO websocket connected to wss://domain.com/api/v4/websocket?connection_id=&sequence_number=0
2024/07/01 00:27:46:773 INFO wss://domain.com/api/v4/websocket?connection_id=&sequence_number=0 got connection id idrand
2024/07/01 00:27:46:886 INFO WEBSOCKET RECONNECT MODELS BATCHING TOOK 17ms
2024/07/01 00:27:47:053 DEBUG error on fetchBindings Received invalid response from the server.; JSON could not be serialized because of error:
2024/07/01 00:27:49:327 DEBUG Not updating badge count, since we have no mentions in the database, and the number of notifications in the notification center is 1
2024/07/01 00:27:52:129 INFO Running "Settings
@Eooooq According to the logs several times the database could not find any mention unread in the server.
Do the notifications you receive generate a mention badge inside the app?
Doing local tests, if I have a channel notification setting to send a notification for all messages, only the ones where I am strictly mentioned generate a badge. Is this what you are experiencing? Or does this happen for you for messages that generate a badge in app? (e.g. direct messages or explicit mentions)
Settings - Notifications - Mentions: @channel, @all, @here [on]
If the message mentions @all , Badges display correctly
I get notifications for unmentioned messages, but my badge doesn’t increase.
I’m receiving messages from bots that don’t include mentions.
Do I have to have a mention to see the badge?
I believe the badge should show even if there are no mentions.
