Hi devs,
ENVIRONMENT DETAILS
Device: iPhone 7 emulator
Mattermost-mobile version: 1.3.2
mattermost-server version: 5.7.0
I’ve deployed custom versions of mattermost-server (which is working totally fine so far), mattermost-mobile and mattermost-push-proxy.
The android version (Variant=release) is working absolutely fine (loading images, uploading images, receiving notifications as far as I have tested it but the problem is that the iOS app doesn’t seem to load the images in channel discussions. There are warnings showing that the image files could not be opened. When I navigate to Image path in the warning, there exist image files but they are not completely downloaded (have size around 196 bytes).
iOS apps are not receiving the notifications as well. Push proxy shows that the iOS push proxy has been initialized. For android devices server logs show that the notifications has been sent but for iOS device there is not log as well.
When I log in using iOS device, server logs contain something like
Sep 21 11:18:08 ip-172-31-13-5 mattermost[6841]: Sep 21 12:10:57 ip-172-31-13-5 mattermost[17038]: {"level":"info","ts":1569067857.2514904,"caller":"web/handlers.go:104","msg":"Invalid session","error":"GetSession: Invalid session token=pd3r4jsc77rb3esqk66c37jzrc, err=<no value>, "}
Then for every failed image load attempt there is an error on the server like:
Sep 21 12:11:03 ip-172-31-13-5 mattermost[17038]: {"level":"debug","ts":1569067863.8508961,"caller":"web/context.go:76","msg":"Invalid or expired session, please login again.","path":"/api/v4/users/6bocgombh7yaipghu8nmbu3xar/image","request_id":"uz5yix33cbg6bp75fs6weo959e
I am running the mattermost on iOS simulator XCode.
iPhone 7
XCode logs is constantly showing these errors:
Mattermost[38711:1437732] [] nw_socket_handle_socket_event [C842.2:1] Socket SO_ERROR [61: Connection refused]
2019-09-21 17:13:04.361929+0500 Mattermost[38711:1439481] [] nw_connection_get_connected_socket [C842] Client called nw_connection_get_connected_socket on unconnected nw_connection
2019-09-21 17:13:04.858602+0500 Mattermost[38711:1439481] [] nw_socket_handle_socket_event [C843.1:1] Socket SO_ERROR [61: Connection refused]
2019-09-21 17:13:04.861387+0500
Any Idea what might be the issue ?
