Due to Government Requirements in our field, we are not allowed to use Mobile Apps that make use of the Camera or Microphone. Is there a simple or easy way to fork the Mobile App code or make use of MDM AppConfig to disable that capability? We’re not able to use the App currently, and its limiting our MM construct.
@elias Would you happen to know if there is a way?
Thanks Amy! I hate to fork and go wide, but its hindering adoption pretty terribly. So Ill listen for good ideas, for sure!
