Matterpoll 1.0.3 got released. Matterpoll is a Mattermost plugin which allows users to create polls via a slash command.
This releases fixes two bugs:
- The command hint had a wrong text. This has been fixes.
- The internal database schema was using wrong versions. This could have been bad, but be found the bug and fixed it.
The pre complied binary is available on GitHub.
If you like the plugin give it a
Hugo thanks to @kaakaa for the continuous effort he puts into this project!
