Plugins reset in each startup. I want to mantain my current installed plugins.
Im running my own instance of mattermost-app with docker (follow GitHub - mattermost/docker: Redesigned mattermost-docker). I have all data in volumes (plugins, client/plugins, data, logs, config).
To reproduce this error:
- Install a plugin in a running mattermost app (using marketplace)
- Restart mattermost app (recreate mattermost-app container)
- Then you can see that your new plugin is not installed.
I expect that Mattermost save the installed plugins and when I restart my instance maintain all my configurations.
When I restart the container I can see that all the files inside “plugins” folder are deleted and 4 plugins are installed (focalboard, welcomebot, playbooks, mattermost-plugin-gitlab)
