Post Edit Time Limit Is Stuck on Default Setting
Mattermost 6.6.1
Hi there,
I updated config.json to have -1 for the PostEditTimeLimit setting. I expect the post edit time limit to be infinite. I’m having users report that there is a 300 second time limit when they try to edit a post. It seems the config.json setting is now deprecated but I can’t seem to find where else I could tweak this setting.
Thank you.
What is the system console setting set to from System Console > Permissions > Manage Posts > Edit Posts > Edit Own Posts?
We have a related ticket open also: [MM-42966] - Mattermost.
Found the setting! Thank you
