Push notification don't works
not receive push notification (Android & iOS) device.
Running Version: 4.0.0 (4.0.1) on https with Let’s Encrypt
without Enterprise License.
Enable Push Notifications: Use iOS and Android apps on iTunes and Google Play with TPNS
Push Notification Server: http://push-test.mattermost.com
Push Notification Contents: Send full message snippet
I not receive push notification on my device. In App Mattermost Chanel the msg will receive.
set logfile to debug
[2017/08/04 13:24:02 UTC] [DEBG] Sending push notification for user 7updtx6izidkpq87szmybbgdzr with msg of 'usertest in monitoring: @here this is a nother test debug 1'
[2017/08/04 13:24:02 UTC] [DEBG] Sending push notification to device b299b5b9ea6b7a72cb3703bd3030d7a12351a3e46de50546bb580acad4afd518 for user 7updtx6izidkpq87szmybbgdzr
Hi @Lordi,
Thanks for your feedback,
Perhaps this discussion will help. There is also this documentation that might help you troubleshoot.
