I was seeing the requirements for a good functioning of your system and I am here with a “problem” to understand and wanted to clarify some things:
My VPS has: 1 vCPUs / cores, 4 GB of RAM
You can see the following:
250-500 users - 2 vCPUs / cores, 4 GB RAM
How much is my visit or more?
Are you already a simultaneous user or a total registered user?
Thank You
Could you help me? is that I really need help so I can make some creations and move on to my project
@diogorocha18 those numbers are estimates. The exact number of simultaneous users that your installation can support will rely on a number of factors. If you would like to repeat the test that we used to determine those numbers, you can take a look at our load testing suite.
