currently if i switch to a different channel the right panel (pinned posts, flag) don’t change. So i have to do it manually. Is there a way to automatically do this?
Thanks.
Thanks.
Also additional to that:
I want so share files that was uploaded on mattermost with a direct link. Logged in users are getting the file perfectly fine, but not logged in users. They getting a nasty javascript error.
Can I redirect this error to a login prompt?
(Sorry for doublepost and bad englando.)
Hi @slimenation,
Thanks for your questions,
For the right-hand-side bar, there isn’t a way at the moment but in upcoming versions, there will be changes to the right-hand-side that will greatly improve user experience.
For the sharing of files from Mattermost to users not logged in, see this documentation
