[SOLVED] Can't enable TPNS for push notification
Hi, i’ve installed mattermost server TE with docker (https://github.com/mattermost/mattermost-docker) and cannot enable TPNS for mobile push notification, when select Use IOS and Android apps on iTunes and Google Play with TPNS and click to Save, the field Enable Push Notifications set to Do not send push notifications automatically
001
after click Save return to Do not send push notifications
Any idea?
I’ve resolved modifyng directly config.json in this way:
"PushNotificationServer": "http://push.mattermost.com",
"PushNotificationContents": "generic",
Thanks for posting back your resolution @stefanocog!
