When i run the platform, it came out this error.
I can’t find anything in google to fix it.
This file “mattermost” is below /opt
Can anyone help me??
[root@localhost bin]# sudo -u mattermost ./platform
Error opening config file=config.json, err=While parsing config: invalid character ‘v’ in string escape code
Hi @hugo.cheung,
Thanks for your feedback,
Can you tell me which version of Mattermost you have installed?
Here are some docs that might help:
Thank you.
I have fixed the problem
Since my password includes “/”, the config cannot run.
I change the password, it works now.
Awesome! Thanks for posting back your solution @hugo.cheung
