[SOLVED] JIRA Beta Plugin Not Available on 4.5.0
In a brand new instance of MatterMost using 4.5.0 the JIRA Beta Plugin doesn’t seem to be appearing.
Install 4.5.0 Enterprise Enabled Version
4.5.0 Enterprise Enabled: true
In the side bar I’d expect to see, under plugins, the JIRA Beta Plugin should be appearing for configuration.
Don’t see the JIRA Beta Plugin for integration. I do see it in 4.3.1 on my test machine. No JIRA
Hi @KnechtionsCoding,
Thanks for your feedback,
A quick question - have you enable plugins in PLUGINS (BETA) > Configuration > Enable Plugins ?
Here is some documentation that might help:
Let us know if you still experience an issue…
Yes. Here is a screenshot of the plugins page: Plugins Enabled
and to confirm that I went to the config.json where it is also enabled.
Note, I’m more than willing to download and upload the JIRA plugin, but I don’t have a copy accessible for me to upload of the 4.5 version.
@KnechtionsCoding Is there anything plugin-related in your logs? You may have a filesystem permissions issue or something like that.
If you want to try uploading the plugin manually, you can download it here: https://github.com/mattermost/mattermost-plugin-jira/releases/tag/v0.1.2
Here is my logs:
[2018/01/03 08:34:22 EST] [EROR] /api/v4/plugins/webapp:GetActivePluginManifests code=501 rid=ifrb9djiefbcjjbhk3zpnsw7so uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:34:35 EST] [EROR] /api/v4/plugins:GetPlugins code=501 rid=x9fmiwi3s38bmr9y7tmi7ua4uw uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:34:42 EST] [EROR] /api/v4/plugins/webapp:GetActivePluginManifests code=501 rid=tewu6didepnkfykpf9dmr7h9za uid=uuwht15p8fnpzga66eo6imgaec ip=172.16.11.61 Plugins have been disabled. [details: ]
[2018/01/03 08:34:47 EST] [INFO] Starting up plugins
[2018/01/03 08:34:47 EST] [EROR] failed to start up plugins: mkdir ./client/plugins: no such file or directory
[2018/01/03 08:34:48 EST] [INFO] Starting up plugins
[2018/01/03 08:34:48 EST] [EROR] failed to start up plugins: mkdir ./client/plugins: no such file or directory
[2018/01/03 08:34:52 EST] [EROR] /api/v4/plugins/webapp:GetActivePluginManifests code=501 rid=td8yzm69it8om8bdjaih8dye7y uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:34:55 EST] [EROR] /api/v4/plugins:GetPlugins code=501 rid=rqzn76neffnpunow83kgzsy6fy uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:35:00 EST] [INFO] Starting up plugins
[2018/01/03 08:35:00 EST] [EROR] failed to start up plugins: mkdir ./client/plugins: no such file or directory
[2018/01/03 08:35:06 EST] [EROR] /api/v4/plugins/webapp:GetActivePluginManifests code=501 rid=hn98ghpfypr18yi9n55wcbupka uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:35:07 EST] [EROR] /api/v4/plugins:GetPlugins code=501 rid=zkd87nfc7tyt8mjx96s9m1s8ye uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:37:45 EST] [EROR] /api/v4/plugins:GetPlugins code=501 rid=behk9g6fr7gjufedphacc6765e uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:37:49 EST] [EROR] /api/v4/plugins:GetPlugins code=501 rid=7j55yb6x33yg3fdjws38og88gh uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
[2018/01/03 08:37:59 EST] [EROR] /api/v4/plugins:installPlugin code=501 rid=gwnjacdtfp8cuq9hqk4o9majjr uid=97mxkppn7tr3pyw7jg1pik8ony ip=172.16.11.196 Plugins have been disabled. [details: ]
However when I check the file system permission they appear to be intact:
Filesystem permissions
I tried uploading the plugin manually and it told me plugins were disabled?
@KnechtionsCoding Can you share the service configuration you’re using?
For example on Ubuntu 14.04 it might be:
start on runlevel [2345]
stop on runlevel [016]
respawn
limit nofile 50000 50000
chdir /opt/mattermost
setuid mattermost
exec bin/platform
Running on CentOS, here is the service configuration:
mattermost
Do I need to move it up a directory to the /opt/mattermost/ directory so it finds client?
Try setting your WorkingDirectory to /opt/mattermost, that should fix it
Okay. I took the documentation from here: under the service part:
https://docs.mattermost.com/install/install-rhel-71.html
So that should probably be updated.
That now resolved it. Not sure if I can submit a PR to update that documentation anywhere.
@KnechtionsCoding If you click the “Edit” button on the top right corner of the page, you can edit the page and submit a change for us to review.
That would be very much appreciated!
Done. This issue can now be closed.
Thanks @KnechtionsCoding, pleased your issue is resolved!
